Show only
Search instead for
Since there is no update on this thread and we have customers strongly disagree with this, we decided to archive this idea. Thank you so much for posting the idea. Keep it going.
I have a feeling all of his assets were made using the default Inventor orientation and he does not want to add landing surfaces or fix them. I had to deal with this issue when I started working with 3D because all the previous parts that were created before I took over were oriented wrong. The landing surfaces were more of a problem in past releases because the constraints created when the asset was placed did not delete automatically as they do now.
We went the direction of using landing surfaces or the Mini-Toolbar to direction assets correctly when they were placed. Depending on your end users, you may run into a lot more problems if the factory plane is reset. For example, 2D drawings like oleg mentioned.
