Insert Hyperlink” option for extended assets in FDS
Can you add the request for FDS to include an “Insert Hyperlink” option for  extended assets in FDS?
2 Comments
XuesongBai
Hi there,
In current FDS, you can add the hyperlink in the asset tag and asset descriptor.  The syntax is the following.
  • From web:[Test]http://www.autodesk.com
  • From local hyperlink: :[Text](file://D:\SharedByXuesong\Refresh%20Asset.wmv)
Note: if the path includes space, you need to replace it with "%20".
-Xuesong
XuesongBai
