Control assets in Factory Layout by form(s) instead of Factory Properties
When working on a Factory Layout it is to bad that the parameters can be changed trough the 'Factory Properties' only. You can't change the names of parameters, you can't change the order in which they appear, and the parameter names must have under scores. The nice Forms which can be made are not available in the Factory Layout.
My idea is to combine the functionality of the 'Factory Properties' and the Forms, and erase either one of them afterwards. This way Autodesk can reach a great improvement of both the user interface, intuitivity en simpleness of the program. It would anyhow bring the design and the use of assets closer to eachother, in my opinion.
Feel free to ask or share toughts.
Please also refer to:
http://forums.autodesk.com/t5/factory-design-utilities-forum/forms-in-assets-to-be-the-only-user-int...
http://forums.autodesk.com/t5/factory-design-utilities-ideas/factory-properties-like-in-ilogic-formu...
http://forums.autodesk.com/t5/factory-design-utilities-ideas/asset-parameter-real-names-groups/idi-p...
6 Comments
XuesongBai
XuesongBai
Status changed to: Accepted
XuesongBai
angela.cao
This Idea is being tracked in:
FDS-11326, FDS-11327, FDS-11328, FDS-11442, FDS-11444, FDS-11449, FDS-11465, FDS-11497, and FDS-11498
Angela Cao
angela.cao
Parts of this Idea have been implemented in the Factory Design Utilities 2018.1 release. Thank you for voting on this feature!
To learn more about this new feature, see Customization Enhancements in the What's New.
Please keep posting your great Ideas and voting on your favorites!
Thank you,
Angela Cao
Autodesk Learning Content Developer
XuesongBai
