Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Asset Republish
Asset Republish
When Creating Assets, often I have to repeatedly republish the asset. It would be nice to have a Republish workflow that could do the following with one button:
- publish to same folder
- publish with the same asset name (to overwrite)
- Set 2D View Options.
Also, if the asset has already been published, these setting should be remembered.
7 Comments
mike_jolicoeur
Logos_Atum
That sounds pretty useful... i hope your idea makes it.
That's a great idea ! There's actually no easy way to update an asset, it's clearly missing.
AndersVT
Great idea
TAR_Loki
The easiest way could be, that the last path to the asset will be saved like in windows.
I mean. When you publish the asset. Make your tests and after fixing your problems, you might be in the same folder as before.
XuesongBai
The function has been implenmented in FDS 2016. Users can edit the library asset in the same folder,same name with 2d view option remembered as last publish.
Furthermore, the update assets command is available to match the edit asset command. So the newly edited assets will be replaced for the old version of asset instances. Of course, users have the control if to replace or not.
-Xuesong
XuesongBai
