I'd like to use iLogic to access parameters of factory assets inserted into a factory layout.
Example: A few days ago I tried to access parameters of inserted factory assets using iLogic and it could not be done. I wanted to create a simple iLogic form that would show how many wall panels remains to be inserted into the wall frame (wall frame was also a factory asset and was driven by its length, width and height). Values should be taken from parameters of inserted assets. Currently it is possible to see and change factory asset parameters only in its own parameter window.
Best regards,
Martin Madaj.
