This options are to easy to get the right position. In many cases the text needs to be specific to a location. Otherwise it will overlap with other geometry.
See this picture below: The block on the right is ok.
The asset (created by 2D asset creation) on the left, looks not great in the way the text is positioned.
The options for the text orientation with "below" or "center" is ok for an automatic process, but not for an final position.
Think about, this text will be printed and therefore it needs a good position.
When I edit the block and move the text position - than it needs to stay where I defined.
So my question is, can we add a option who say "Use Defined Text Position" with an check box?
Many thanks and regards
Frank
