Hi All,
I want to have an immersive experience (HTC vive or Oculus Rift) of the factory that I designed using factory design suite and also the simulation of my factory in Virtual reality. Is it possible and if yes, how?
Also when i am having an immersive experience of the factory I would like to make some changes in it (like move a machine or add a machine) with the help of controllers that are available with current high-end VR headsets. Is it possible and if yes, how?
I have attached a small video of factory design suite that is available on you tube also just to convey my questions clearly.
Any feed back would be appreciated
Thank you in advance.
Regards
Naishal Thakker
Hi Naishal,
The answer is Yes for your firstly question.Most users prefer the HTC vive for the immersive experience in factory. You can try to use Autodesk Stingray or Vred as the platform to do that.
For your second question: There is not good solution to move or add new machines in the VR headset experience.
-Xuesong
Hi Xuesong,
Thank you for your time and reply.
I had one more question, out of the many VRED options available( VRED, VRED Design and VRED Professional) which one should I use for my purpose?
Regards
Naishal Thakker
