Hi all,
I am a beginner and having a doubt. Really appreciate if anyone can help:
In the process analysis 360, I can see the User cloud assets, but I can not see the assets that I stored locally. I can see those locally saved assets in other software like Architecture, Mechanical, Inventor, etc. but not in process analysis.
Anyone has faced a similar issue or can anyone guide me?
Have a nice day.
Regards
Naishal
Solved by liqinomickey. Go to Solution.
Solved by XuesongBai. Go to Solution.
That is not an issue but just as designed. PA 360 is limited to use the assets in the public cloud or user cloud library.
-Xuesong
Hi Naishal,
Sorry, but as Xuesong said, only Public cloud and user cloud asset could be seen in PA360. So that when you logged in PA360 in another machine there will not be any data loss.
If you want to use local assets, here are some ways:
1, If you are going to export the PA model to dwg in the future. You need to Republish the assets to the cloud, or Copy/Move asset from local to cloud in either Inventor/AutoCAD asset browser.
2, If you are not goint to export the PA model to dwg in the future. Then you can assign the node with image, which could be found in your local asset library folder.
Thank you,
Mickey
