Hello!
I am creating blocks for Factory and am facing the following problem:
When I insert into a layout two occurrences of the same block while editing one another receives the same updates even though they are different occurrences.
Follow the images below:
As you can see in the highlights this "code" that I believe to be generated by the Factory is the same in both instances soon the Inventor should "understand" as the same piece.
Considerations to be made:
- the blocks are modified through changed parameters via the graphical interface of an Add-In.
- I'm doing the Add-in in C#;
- I look for the item to be changed in the assembly through the commandPicker looking for a ComponentOccurrence;
- the block has illogic rules (I do not think it influences);
Thanks for the collaboration.
Solved by olegd.prod. Go to Solution.
Is there any possibility of manipulating the Factory panel through the API?
I would like this because in this block there are many settings besides information that I need to look for in a database for example...
Thanks for the answer!
Hello.
I can not believe that Autodesk did not do this editable via API, but we'll expect it to be implemented in future releases.
Thank you very much.
