unable to "Open in Inventor"
nstalker
Message 1 of 15
nstalker
getting this message when I select the "Open in Inventor" button.
"The template file you're trying to open doesn't exist. Please check or reset the Factory layout template in the Factory Options and try again."
Using AutoCAD Mechanical 2022 with Inventor Professional 2022.
Replies (14)
Message 2 of 15
liqinomickey
Hi @nstalker ,
Would this Restore Defaults work for you in Inventor Factory Options?
Mickey Li
Product Manager
ACS Docs Platform feature team
Autodesk, Inc.
Message 3 of 15
nstalker
No when I click that it doesn't give me the option to apply any changes so I assume I am already set to defaults
Message 4 of 15
liqinomickey
@nstalker
would you please navigate to that folder and find if that template is there?
And if you are using one localized version of Inventor but another localized version of FDU, that could cause the mismatch in template folder. As you can see it is targeting an "en-us" folder.
Mickey
Mickey Li
Product Manager
Autodesk, Inc.
Message 5 of 15
nstalker
I browsed to that folder and the templates are not there. I reinstalled FDU 2022 and they are still not there.
Message 6 of 15
liqinomickey
Hi @nstalker ,
Are we installing a localized language of Inventor or FDU?
%PUBLICDOCUMENTS%\Autodesk\Inventor 2022\Templates\en-US\StandardFactoryLayout.iam
As you can see the folder points to a "en-us" folder. Are you seeing other folders in:
Mickey Li
Product Manager
Autodesk, Inc.
Message 7 of 15
Me too when I click that it doesn't give me the option to apply any changes so I assume I am already set to defaults
snaptube
vidmate
Message 8 of 15
nstalker
the factory template is in neither folder
Message 9 of 15
liqinomickey
Hi @nstalker ,
That's strange, would you please search C:\ drive to find if we have "StandardFactoryLayout.iam" installed somewhere?
Are we using a default project file or customer project file? And the template folder is targeting where?
Thank you,
Mickey Li
Product Manager
Autodesk, Inc.
Message 10 of 15
liqinomickey
Hi @Anonymous ,
I saw you replied in this thread:
https://forums.autodesk.com/t5/factory-design-utilities-forum/can-t-save-editted-assets-created-orig...
Did that solve the issue here? Thank you.
Mickey Li
Product Manager
Autodesk, Inc.
Message 11 of 15
nstalker
It shows up in my 2020 folder and my 2021 folder but not my 2022 folder
Message 12 of 15
liqinomickey
Hi @nstalker ,
It should be in a folder C:\Users\Public\Documents\Autodesk\Inventor 2022\Templates\en-US
Would you please try to uninstall and install FDU to see if the file is created? Thank you.
Mickey Li
Product Manager
Autodesk, Inc.
Message 13 of 15
nstalker
will do. FYI I am not the admin of my PC. Also, some standard folders like desktop, my documents, downloads etc are re-routed to C:\Users\nstalker\OneDrive instead of the usual locations per company policy. Just letting you know in case this gives you any insight into the problem. I will update this thread once I get IT to uninstall and reinstall.
Message 14 of 15
nstalker
it worked after uninstalling and reinstalling and updating my software
Message 15 of 15
gourav_patil6VEWT
can i get setup of  FDU 2021 version either share me file of "StandardFactoryLayout.iam" 2021 vesrion
