Hello for all!
It's possible to show asset tag on Inventor drawing?
How to make this?
I would like to change item number for asset tag.
Change this:
For this:
However, if exists many assets with the same instance with different configurations happens this:
In this case I make the asset tag with two information of my process and I insert iproperty STOCK NUMBER and show it in the balloon.
Thanks!
Solved by olegd.prod. Go to Solution.
Hi!
About the values in the balloon:
5 is default, the value of the item in assembly.
AZS 001 is the information I want to appear.
and *Varies* It happens when I enter more than one item, even with a different instance of the same asset.
How are 3D layout details done?
Hello!
Thanks for help!
Video below:
Yes, Inventor BOM part number matching turned on!
Now is working fine!
Thanks!
