Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Show asset tag on Inventor Drawing
6 REPLIES 6
ederson.balbinot
849 Views, 6 Replies
Hello for all!
It's possible to show asset tag on Inventor drawing?
How to make this?
I would like to change item number for asset tag.
Change this:
For this:
However, if exists many assets with the same instance with different configurations happens this:
In this case I make the asset tag with two information of my process and I insert iproperty STOCK NUMBER and show it in the balloon.
Thanks!
Best Regards,
Ederson Balbinot
Software Enginner
Kudos are much appreciated if the information I have shared is helpful to you and/or others. Thanks!
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Tags (3)
6 REPLIES 6
Hi there,
In general, the answer is no -Asset Tag is a per-instance Factory property, and isn't accessible to Inventor Drawings.
With that said, I am not sure what you did to go from "5" to "AZS 001" to "*Varies*"? Can you record a video showing your workflow?
Thank you,
Oleg
Hi!
About the values in the balloon:
5 is default, the value of the item in assembly.
AZS 001 is the information I want to appear.
and *Varies* It happens when I enter more than one item, even with a different instance of the same asset.
How are 3D layout details done?
Best Regards,
Ederson Balbinot
Software Enginner
Forgive me for being slow, but what does "I enter more than one item" mean? "Enter" where? Can you include a video/screenshots/etc
Oleg
Hello!
Thanks for help!
Video below:
Best Regards,
Ederson Balbinot
Software Enginner
I am going to guess that you have Inventor BOM part number matching turned on.
If you turn it off, you should get what you are looking for, but only because of how you are building your "asset tag".
You seem to be using Inventor parameters to "build" the asset tag. Nothing wrong with that, but this is not how we intended things to work.
In your scheme, 2 identical asset instances that only vary in your "asset tag" will still result in 2 different files, and in 2 different BOM rows (with the part number matching turned off).
In our scheme, "asset tag" is a per-instance property, so 2 instances backed by the exact same file can have different asset tags. This is the data I was referring to when I said that there is no way to get that into a drawing.
HTH
Oleg
Yes, Inventor BOM part number matching turned on!
Now is working fine!
Thanks!
Best Regards,
Ederson Balbinot
Software Enginner
