Hello All,
I am using Factory cad 14.0. I am importing JT files to create the plant layout and file size is too large.While importing JT file I am using the lowest LOD even though I could not able to reduce the file size. Is there any solution for reducing the file size? Can anyone help me in this?
Ahil Raja T M
Hi there,
Some users use the following options when exporting DWG to JT.
Thanks.
-Xuesong
Thanks Xuesong,
I tried the option and the file size is not getting reduced.JT files I am importing (Tools) are 10-20 MB size and when I reduce the LOD and Decimation less than 0.3 top view of the tool is not clear. When I give LOD above 0.3 DWG size is too big. Is there any way to reduce the file size while importing.
Ahil Raja T M
