Process Analysis
Process Analysis
portizPW7R6
Process Analysis
portizPW7R6
Hi
I can't simulate a process of more than 360 pcs/hr no matters the processing time always have a maximum production rate that 360 pcs/hr
I appreciate any help
thanks
XuesongBai
Hi there,
The process analysis is simulating the correct result. I think the bottleneck should be on the material flow of  transportation. So please check the select the connection line and set the transportation time to reflect the real-status.
-Xuesong
Please mark as a solution if somehow I got it right.
portizPW7R6
Thank you
that's was the problem!!
