Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Process Analysis - Server Error
9 REPLIES 9
Message 1 of 10
1138 Views, 9 Replies
I have a problem with running the Process Analysis.
Server Error 500 - Internal server error.
Everything worked well before.
I do not know what to do.
I will be grateful for any help.
9 REPLIES 9
Message 2 of 10
liqinomickey
Hi Martin,
There is a recent update to support SSO (single sign on). So could you please go to your installed program to check if "Autodesk Single Sign On Component" is installed? If not, please uninstall "Autodesk Process Analysis" and go to our website to download PA setup to install again. The setup will trigger SSO installation automatically. Please tell me if this will fix the problem.
Sorry for this inconvinience. Good day!
Mickey
Mickey Li
Product Manager
ACS Docs Platform feature team
Autodesk, Inc.
Message 3 of 10
in reply to: liqinomickey
Hi Mickey,
Thank you for support me.
I followed by the instruction and still the same problem.
Message 4 of 10
jzhangustc
Martin,
Are you working behind your company firewall?  This may be due to network requests that are blocked by the firewall.  Can you use Fiddler to watch your network traffic from Process Analysis?
Jun
https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png
Message 5 of 10
I am running into another error on the connection to the server as well, popup in the top left.Screenshot (47).png
Message 6 of 10
jzhangustc
Please uninstall Process Analysis and reinstall it from the following link.
http://processanalysis.autodesk.com
Let me know if it solves your issue.
Jun
Message 7 of 10
I am having the exact same problem, 500 error.
I tried several installs without success.
I used the link provided above.
Am i missing a component ?
Gabriel Roussie
Message 8 of 10
Gabriel,
Are you working behind your company firewall?  This may be due to network requests that are blocked by the firewall.  Can you use Fiddler to watch your network traffic from Process Analysis?  The link of Fiddler is https://www.telerik.com/fiddler.
The firewall needs to allow the visit to the following URLs,
accounts.autodesk.com
cdn.accounts.autodesk.com
api.autodesk.com
Please let me know if you need any further help.
Jun
Message 9 of 10
Thanks, got it to work.
Message 10 of 10
stuartf
in reply to: Gabriel_Roussie1
Hi Gabriel, how did you solve the problem? I am having a similar issue.
