Hi all,
I work with Autodesk Factory Design Suite Ultimate 2017 and Vault Professional 2017.
I create a new DWG from an old and native DWT template => OK
I create a new DWG from a new template (customized) => After the 1st check in Vault, my dwg is linked to a new Custom Object in the family "Factory Layout".
Same problem if Factory Add-in is unload in AutoCAD. Same behavior if I check-in from Acad or AcadM.
I don't use VDS.
I have the issue in 2 vaults that have FactVault.cfg configuration.
Can you explain what is the hidden or magic property that create a custom object during dwg check-in ?
Thanks in advance !!!
Best regards,
Solved by olegd.prod. Go to Solution.
Hi Oleg,
Factory add-in is not loaded, as you can see in the Screencast.
The result seems to depend of the template I use.
Hope it helps !
I sent you a link to download my templates.
Hi Oleg,
1. You're right, FACT_ABOUT still give me factory about dialog.
2. Your workaround works for me.
Thanks a lot for your answer !
I'd like to know how to manage these "meta-data" that create a Vault custom object, but as I think it's impossible, I'll try to make my templates again from scratch.
Thanks again for you help. Quick and Accurate.
Best regards,
Irénée.
Hi again
Still about these meta-data in my template : is it possible to delete it using API ? Do you have a lisp (or other) that permitt to supress these Factory meta-data ?
Because I just had a look on my templates, and it's a lot of job to make new Templates from scratch.
Thanks in advance, and have a nice week-end,
Irénée.
