Inventor is not opening from Architecture
cjuliao
Message 1 of 33
cjuliao
Hello everyone,
1st of all, hope everyone is alright,
In ACA, I want to create a mockup factory, to open afterwards in Inventor, but guess what:
Factory "design" utilities isn't working in ACA neither opens Inventor ( the _FACT_OpenInventor appairs in the command bar but nothing happens)
Also the pallets/browser of the factory assets does not open.
Attached to this post are 2 print-screens:
IMG_1 - Autodesk installed programs;
IMG_2 - ACA "dummy" project where you can see the commands active (but it does not work)
Does this has anything to do with the adress of the intallers? or any thing that i did to install the ACA and Factory utilities?
Is there any installing procedure? (that i probably didn't follow) for example: 1st-Inventor, 2nd ACA, 3rd-Factory utilities.
Best of health and regards,
Replies (32)
Message 2 of 33
olegd.prod
The first I'd try is to uninstall and reinstall FDU for ACAD and Inventor
Message 3 of 33
liqinomickey
Hi @cjuliao ,
How about the commands in Inventor? Are Factory commands working in Inventor? Thank you.
Mickey
Mickey Li
Product Manager
ACS Docs Platform feature team
Autodesk, Inc.
Message 4 of 33
cjuliao
The same thing as ACA, it does nothing.
Message 5 of 33
cjuliao
Already did that.
Message 6 of 33
olegd.prod
Hmmmm
Check your license in the "? | About ACAD/Inventor menu" - what type of license do you have?
I am grasping at straws here
Message 7 of 33
cjuliao
Both (ACA and Inventor)
Type: Commercial
Term: Time expandible
Experiation date: None
if your grasping straws imagine me.
Do you think the best way is to reinstall everything, again?
Message 8 of 33
liqinomickey
Hi @cjuliao ,
There should be another license for Factory Design Utilities inside the license page. Please wait a little bit after excuting the Factory command. And see if this license comes up in that license page. For both Inventor and ACA, there should be 2 license listed in this page. 1 for Inventor/ACA, 1 for FDU.
Mickey Li
Product Manager
Autodesk, Inc.
Message 9 of 33
cjuliao
IS it this?
i got the collection
Message 10 of 33
liqinomickey
Hi @cjuliao ,
In License Manager, there should be two products listed:
Is the Factory Design Utilities listed after excuting Factory Commands?
Thank you,
Mickey Li
Product Manager
Autodesk, Inc.
Message 11 of 33
cjuliao
In inventor
In ACA
It doens't popup nothing related to FDU after a while (when i clicked on all the FDU buttons)
What more information or testing do you need to help to filter the problem?
Message 12 of 33
liqinomickey
Hi @cjuliao ,
Thank you for your understanding. I think we have located the casue of this issue. The FDU license check might have been taking long time, and it seems the commands are not responding.
  1. Would you please try on your machine, Launch ACA, new a dwg, and Click one of the Factory commands, then go have a cup of coffee. after 10 minutes lets see if the commands excutes.
  2. After step 1, go to folder: (replace *username* with current user name) zip up what's inside and send back to here. (or send to [email protected])
    C:\Users\*username*\AppData\Local\Autodesk\Web Services\Log
Thank you very much.
Mickey Li
Product Manager
Autodesk, Inc.
Message 13 of 33
cjuliao
Nothing happend unfortunately.
what should i pay attention to?
Message 14 of 33
KevinHu_PDMS_Vault
Please try to reset the FDU license with below command line
"%CommonProgramFiles(x86)%\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe" change --prod_key p03L1 --prod_ver 2020.0.0.F --lic_method ""
Then to see if you see the license Let's Get Start dialog when you use FDU functions.
Message 15 of 33
cjuliao
Hi Mr. Kevin,
I did what you told me to do, what happend is the following:
I oppened the AdskLicensingInstHelper.exe and it oppened some sort of command-console window (with a black background) but it closed very quicky. No time to write something down.
I even tried opening it with "executing with administrator access", the same thing, it closed very quicky.
Should i reinstall all 3 of the programs? (Inventor, ACA and FDU)
Best regards
Message 16 of 33
KevinHu_PDMS_Vault
Hi, please first start the command prompt console (Start -> Run -> input "CMD"), then copy that command line in it and run.
Message 17 of 33
cjuliao
Hi kevin,
Thanks for the response.
Attached to this reply of mine, is a image (print-screen) i dont know how to work with the Change command i think i did what you wrote: Change (option) --prod_key .....etc.
Best regards
Message 18 of 33
cjuliao
hi again,
Okay i think at least the command thingy work, but on ACA and inventor the FDU still doesn't work.
Attached to this reply is another screen-shot.
Message 19 of 33
liqinomickey
Hi @cjuliao ,
Just to confirm, do you have "Factory Design Utilites 2020.1.1 - Inventor/AutoCAD Factory" installed in your iinstalled updates? I am asking because we once had an issue where standard user for the machine cannot access Factory commands. But we fixed in 2020.1.1
Mickey
Mickey Li
Product Manager
Autodesk, Inc.
Message 20 of 33
cjuliao
Hi, thanks for the quick response,
Call me dumb, but i actually didnt update FDU for AC and Inventor on that version your telling.
Going to update it right now, and tell you the outcomes.
