Inventor Factory Allow Exploding block
Darkforce_the_ilogic_guy
Advisor Advisor
Factory makes an AutoCAD drawing where alle the assets are block with Allow Exploding set to No..
Is there a way to make theis be set as Yes as standard ?
what I need it to find an easy way for an AutoCAD LT to be enble to editing in this files if need be .  I have an script for AUTOCAD that can do this but it does not work in AutoCAD LT sind it does not support it... so it would make it easier if it was not set to  Allow Exploding =No
liqinomickey
Hi There,
Unfortunately, changing multiple blocks' "Allow Exploding" property is not available in AutoCAD LT. So, it might need to be changed one by one. Or before sending to LT, it would be very simple to reset the group code 280 property of a block with AutoLISP in AutoCAD.
Thank you,
Mickey
Mickey Li
Product Manager
ACS Docs Platform feature team
Autodesk, Inc.
