iLogic in Autocad
iLogic in Autocad
silvestresallesjunior4
iLogic in Autocad
good morning. my English is not very good. but let's go. Firstly, my name is Silvestre, im working whith factory design. Creating assets in inventor.
I have a doubt. i'd like using the form done whith iLogic in Autocad. Is it possible?
Kenny
Hi Silvestre,
I think, you cannot use the iLogic form in the AutoCAD Factory directly. 😞
However, if you define the Key Parameter as publishing asset in the Inventor, you can use the factory property panel to edit the parameter in the AutoCAD Factory directly,  after you select the asset instance in the layout.
More details about define key parameter in the inventor factory view:
http://help.autodesk.com/view/FDU/2019/ENU/?guid=GUID-3A44C254-56D4-4786-8954-1ADF86584EED
What's more, we do support iLogic from in inventor factory:
http://help.autodesk.com/view/FDU/2019/ENU/?guid=GUID-71F396DB-5B0E-4E22-B7E3-A53DDF5DD565
Hope it helps 🙂
Kenny
Define key parameters as publish asset.
Hello, thanks. I have another question. is it possible to enable and disable parameter switches? I did some testing and this does not work. so you can understand. I think of activating and deactivating parameters in assets according to the users' choices. Example: If the user says that the asset has no leg, it does not make sense to leave the parameter to set the leg height. Therefore, when choosing not to use a leg, the height parameter would be inactive.
olegd.prod
This is not possible currently.
Many users have asked for this, so we are investigating - stay tuned ...
thank you for the feedback, it is very important because I am working on the implementation of the plant, and these resources are essential for the project chain. So that you understand better and have some appeal or suggestion of kindness. I have to watch a flow that goes through several areas, and the diversity of information to be filled diverges, I can not deal with the conceptualization while I treat the application, it does not make sense that in the conceptualization of the project I have to assemble the equipment in detail. Thinking about solving this, with different forms dealing with the same assets, but, in principle, with a more basic conceptualization and then with a better detailing. Thanks again, I hope you can help me. up until .
