All,
In my last post, Oleg helped me to understand how to edit a Vault Asset in Factory Design Suite 2017 and you can find that post below. However, I am now curious if there is a way to control who can edit these assets. I'm assuming that only people that have the appropriate Vault permissions can use the "Edit" workflow to modify a Vaulted Library Asset, but cannot verify at the moment. Can anyone confirm that Vault permissions control this option? Or can someone suggest a different way to control the "Edit" of Vaulted Library Assets? If you have any questions, please do not hesitate to contact me. Hope all is well and have a most blessed night!
How to Edit a Vaulted Factory Asset: http://forums.autodesk.com/t5/factory-design-utilities-general/how-do-i-check-out-an-vault-2017-asse...
Peace,
Pete
Solved by XuesongBai. Go to Solution.
Solved by olegd.prod. Go to Solution.
Hi Pete,
In other to publish/edit factory library asset in Vault, the factory users must have the Role at least as below.
-Xuesong
Xuesong,
Good afternoon! We actually tried to apply the permissions to a user and it didn't seem to work. Which additional permissions do you think I should set up for the user? Thanks in advance for your assistance and have a most blessed day!
Peace,
Pete
Oleg,
My apologies for being too vague. When we tried to publish an asset into the Vault, the user was denied due to a permissions restriction, but I cannot recall the exact text of the error. I logged in as the administrator and could publish without issue. It seems like there are additional permissions that need to be granted, but I wanted to ask before I just started assigning them. Hope this helps to clarify the issue. Have an awesome and most blessed day!
Peace,
Pete
hi Pete,
At least, the following two roles are assigned to the user.
Custom Object Editor Level 1
Document Editor Level 1
Additionally, to be sure the user has the permission to modify the folder which deposited the assets in Vault.
-Xuesong
