Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
How to Control Who Can Edit a Vault Asset in FDS 2017
7 REPLIES 7
Message 1 of 8
petestrycharske
519 Views, 7 Replies
All,
In my last post, Oleg helped me to understand how to edit a Vault Asset in Factory Design Suite 2017 and you can find that post below.  However, I am now curious if there is a way to control who can edit these assets.  I'm assuming that only people that have the appropriate Vault permissions can use the "Edit" workflow to modify a Vaulted Library Asset, but cannot verify at the moment.  Can anyone confirm that Vault permissions control this option?  Or can someone suggest a different way to control the "Edit" of Vaulted Library Assets?  If you have any questions, please do not hesitate to contact me.  Hope all is well and have a most blessed night!
How to Edit a Vaulted Factory Asset: http://forums.autodesk.com/t5/factory-design-utilities-general/how-do-i-check-out-an-vault-2017-asse...
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
7 REPLIES 7
Message 2 of 8
"Edit" will only work if the user has the Vault permission to check out the Vault asset file
Oleg
Message 3 of 8
Hi Pete,
In other to publish/edit factory library asset  in Vault, the factory users must have the Role at least as below.
-Xuesong
Please mark as a solution if somehow I got it right.
Message 4 of 8
Xuesong,
Good afternoon!  We actually tried to apply the permissions to a user and it didn't seem to work.  Which additional permissions do you think I should set up for the user?  Thanks in advance for your assistance and have a most blessed day!
Peace,
Pete
Message 5 of 8
Pete,
What does "didn't seem to work" mean? Errors, etc?
Oleg
Message 6 of 8
Oleg,
My apologies for being too vague.  When we tried to publish an asset into the Vault, the user was denied due to a permissions restriction, but I cannot recall the exact text of the error.  I logged in as the administrator and could publish without issue.  It seems like there are additional permissions that need to be granted, but I wanted to ask before I just started assigning them.  Hope this helps to clarify the issue.  Have an awesome and most blessed day!
Peace,
Pete
Message 7 of 8
Pete,
I don't have a running Vault environment right now, but Xuesong's info in this thread is consistent with my notes (yes, I realize that this doesn't help you much :)).
I am sure Xuesong has a Vault environment, so let's wait for him to double-check this.
Oleg
Message 8 of 8
XuesongBai
in reply to: olegd.prod
hi Pete,
At least, the following two roles are assigned to the user.
Custom Object Editor Level 1
Document Editor Level 1
Additionally, to be sure the user has the permission to modify the folder which deposited the assets in Vault.
-Xuesong
