I have multiple templates in the template folder,ACAD is pointing at that folder!
Solved by JamesThorpe4547. Go to Solution.
Solved by XuesongBai. Go to Solution.
Hi there,
Could you please read the thread in another same topic?
http://forums.autodesk.com/t5/Autodesk-Factory-Design-Suite/Can-t-publish-asset/td-p/3533150
-Xuesong
I copied both the English and Metric folders into the Vault template location.
Bingo.
Thank you.
Hi Guy´s
A little comment to the above.
I had the same problems after installing Factory Design Premium with Inventor-2017-SP1. I tryed to copy the Metric templates with little luck.
Finally I updated Inventor to 2017-R2 and after that it work fine.
Claus
