I have multiple templates in the template folder,ACAD is pointing at that folder!
Solved by XuesongBai. Go to Solution.
Hi there,
Could you please read the thread in another same topic?
http://forums.autodesk.com/t5/Autodesk-Factory-Design-Suite/Can-t-publish-asset/td-p/3533150
-Xuesong
Hi Guy´s
A little comment to the above.
I had the same problems after installing Factory Design Premium with Inventor-2017-SP1. I tryed to copy the Metric templates with little luck.
Finally I updated Inventor to 2017-R2 and after that it work fine.
Claus
