Hi
Is it possible to change the location of the factory assets folder?
By default Inventor creates this folder in the project folder location.
Is possible to point this folder to a different location.
See pic in attachment.
Regards
Luis Mestre
Solved by olegd.prod. Go to Solution.
This would be very useful - several customers have asked me about this. At present you would need to adopt a 'Multiple Project File' method to have a separate Factory Assets folder for each job.
Autodesk - is some flexibility with save location for Factory Assets within a single Project file being considered?
Oelg ....you are pretty much saying what I've said in start of the post. question is ...can Autodesk change it in the future, to be more flexible?
As i understand this option is hard coded in the app and can not be changed. correct?
let me rephrase then.
Can the user change the location of the factory assets folder independently of the project file ( ipj) ? correct answer is NO, correct?
I suggest the same way as we can configure the folder and folderstructure with content center.
So the general folder location and the subfolder with a specific standard or product.
Olegd
Manly because in our organization we have a standard folder structure for all the projects, for content center and libraries we have it more centralized.
The "factory Assets" folder became standard in our organization more or less forced by the application ( Inventor ) see picture attached.
Having the location of this folder more flexible doesn't bring huge benefits, it's more to suit everyone's standards ( folder structures).
