Enabling Vault Client
Mopico
Mopico
What is the precedure for this?  I have tried a re-pair and re-install and cannot find any options to activate the Vault Client.  My install of AutoCad is not Vault aware that I can find anywhere.  Inventntor is okay.  Vault options are present.
This installation was an upgrade from IVPro.  The previous install of AutoCad (mechanical although I ran the vanilla profile) had the proper vault tab that allowed log in/out check in/out etc.  I am currently running the application in "Architectural as AutoCAD "  profile mode.  Running straight Architecture 2011 is not different, no vault.
bagchis
Can you please send me an email (shibai.bagchi@autodesk.com) and copy Joe Doyle (joe.doyle@autodesk.com) with your contact details and we will get in touch with you to understand the scenario better.
Shibai Bagchi
Autodesk, Product Manager
joe.doyle.yyz
Posting the offline resolution of this issue for the benefit of other discussion group participants.
*Scenario: Installed Vault client before installation of ACA, so the add-in isn’t installed on ACA successfully.
*Solution:
1. In Windows Add/Remove Programs, select Vault Client
2. Click Add/Remove Features
3. Check on Addin for AutoCAD Architecture, proceed
4. Run AutoCAD Architecture, check if Vault tab appear on Ribbon menu.
               Reference: http://forums.autodesk.com/t5/Autodesk-Vault/Activating-Vault-for-use-in-AutoCAD-Mechanical/m-p/2746...
*Alternative solution:
1.       Uninstall Vault.
2.       Reinstall Vault from FDS installer.
