Using FDSP 2016 ACAD Mechanical
I used to be able to do a dimscale and then "dim" "up" "all" to update everything to the dimscale I had assigned. This command isn't working anymore. What's the keyboard sequence of commands to update all dimensions to the current dimstyle/scale?
Yeah, it was pretty sad when UP or UPD disappeared. You can type in "-DIMSTYLE" then "A" for Apply or add that command icon to your Annotate Dimensions per this thread. It worked perfect!
