Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Copy of assets when insert in a Lay-out
4 REPLIES 4
marcos.pellizzoni
521 Views, 4 Replies
Hi friends
Is it normal the Factory makes a copy of asset when I insert in a Lay-out?
If yes, why?
I am afraid that my HD will be full soon.
Marcos
Mechanical Engineer
AutoCAD Certified Professional 2015
4 REPLIES 4
Hi Marcos,
A layout may contain many instances of the same asset, each with different configuration (length/width/height/etc), so you are seeing expected behavior.
Thank you,
Oleg
hi Oleg,
Thanks for your response,
But if I make 200 lay-outs using an asset with the same configuration, will I get 200 copies of the same asset?
Marcos
Mechanical Engineer
No, just one. One file per configuration - you can use that configuration many times in the same or different layouts.
Well, to be pedantic about it, you'll get a file per configuration/Inventor version/project file. That is, if you place a 5" conveyor in Inventor 2016 and Inventor 2017, you'll get 2 files. Additionally, these files' location is controlled by the Inventor project file, so if you use multiple projects you may get the same-configured file in multiple locations on disk.
Now you know more about this than you probably ever wanted to know 🙂
HTH
Oleg
Hi Oleg,
Knowledge is always good!
Thank you very much.
Marcos
Mechanical Engineer
