@Anonymous wrote:
Hello Jeff
CER_121656795
CER_121656699
report (121603626)
report (121594462)
report (121531425)
these are some crash report numbers autoamtically generated after sending a failure report.
To switsch off the add ins in inventor i need to know how to search for the settings, since my Programm is installed in German languge.
your question when did it started:
it started with a ADLM report, which meant that Autocad cant find the license manager. Thats about the time when my Microsoft .Net FRamework started posing failures as well. I changed the Framework from 4.5.2 up to 4.6.
Set the adlm report manager from "manually" to "automatically" under Windos - R - Services.
i have switched off Customerinvolvementprogramm
switched off Desktopanalysis
Repaired the Software Factory Design Suite
Re.installed and Installed FDS
right now inventor crashes during synchronizing with Acad...
Hallo und guten Tag,
darf ich fragen wie Sie das Problem gelöst haben? Ich hatte dieses Problem im selben Zeitraum letzten Jahres. Nachdem ich mir einreden hab lassen dass Windows nicht funktioniert habe ich mein Betriebssystem neu aufgesetzt. jetzt 2 Monate später habe ich exakt dasselbe Problem wieder.
Kurios ist, dass Inventor im DEFAULT Projekt alle Dateien bearbeiten lässt allerdings ohne Zugriff auf Bibliotheken. Acad Architecture lässt sích nciht synchronisieren und auch die Multifunktionsleiste ist weg.
App Manager habe ich vor langer Zeit deinstalliert aber updates sind alle aktuell.
Hello there,
may i ask how you solved your problem? i have had this problem around same time last year. After trying many things i have set up my windows7 from new. Somehow FDS ran perfect until this week. Right now i cant work on inventor neither in dwg via Architecure. The only thing that i have noticed is; If i set Inventor to DEFAULT mode i am able to open files and work on them. But Architecture is not synchronizing and the multifunctionbar is missing.
the app manger i have disabled long time ago but all the autodesk updates are up to date so are the windows updates....
best regards
