Hi all,
With the 2017 version, is it possible to change the path of the default "User Assets" Library ?
The path "Users\MyUsername\Documents\Factory Library" is on the network, and limited in size.
It not, is it possible to disable this Library ?
I only use Vault lib.
Thanks, and best regards,
I. Dubail.
Solved by olegd.prod. Go to Solution.
