All,
I'm looking to start using the Vaulted Assets functionality in 2017, but have noticed that the vaulted assets don't look to include comments on the versions when they are edited. In a standard Vault application, I would check out a file, modify it and then check it back in and during the check in process add a comment to list what changes were made. However, it doesn't look like the factory assets in Vault have this functionality. Is there a proper workflow for adding a comment to the asset? If you have any questions, please do not hesitate to contact me. Have an awesome and most blessed day!
Peace,
Pete
Solved by XuesongBai. Go to Solution.
Hi Pete,
Yes, Factory asset can have the comments.But the comment only can be added through factory Asset Properties>-Summary>-Comments.
So finally the comments can be shown up in Vault Asset( both .faf and custom Object).
-Xuesong
Xuesong, this is perfect, exactly what I needed! Hope you and your family and have an awesome and most blessed day!
