Reducing tee’s in the Multi service line
Multi service designline needs the ability to produce reducing tees for branch lines that change elevation. Currently, when drawing branches that change elevation, the main size is applied to the vertical portion of the branch line and then the reducing branch size is applied to the horizontal line resulting in a full size tee with a reducer instead of a reducing tee.
The obvious workaround is to edit the line and fix the constraint of the vertical portion of the branch line but that’s not very efficient if you’re trying to produce a quick estimate.
I feel like I may have already posted this just as Im getting ready to post now - I apologize if this is a duplication.
1 Comment
aaron.tw
Status changed to: Gathering Support
