Show only
Search instead for
A lot of options have been removed from linear nest pipe reports set-up. Like to see same options that are available in other IRP set ups. Spool name and item end are two big ones.
Question, I found this in the forum and it is the closest to what I am looking for. The issue with adding pipe ends to the report has not yet been resolved? I am in the 2016 ver of CAD MEP and still have this poblem. Is this something that is in the works to complete in the next release?
mac, the work around I have found is to set up your .LRP and change the extension to .IRP, add in the fields you want and then change the extension back to .LRP. Then you can report groove end x weld(or whatever) for cutting.
