More options for Linear Nest Pipe Reports
A lot of options have been removed from linear nest pipe reports set-up. Like to see same options that are available in other IRP set ups. Spool name and item end are two big ones.
5 Comments
DJT171
Item Spool Name is the biggest one that needs to be added back
ScottHendricks
Spool name has been added it the 2015 release
andy.robins
mac
Community Visitor
Community Visitor
Question, I found this in the forum and it is the closest to what I am looking for. The issue with adding pipe ends to the report has not yet been resolved? I am in the 2016 ver of CAD MEP and still have this poblem. Is this something that is in the works to complete in the next release?
hbds20
mac, the work around I have found is to set up your .LRP and change the extension to .IRP, add in the fields you want and then change the extension back to .LRP. Then you can report groove end x weld(or whatever) for cutting.
