Show only
Search instead for
Just recently I updated my CAMduct to 2016, with that I am experiencing an issue with all parts that have a radius edge. Is there a switch in my database to eliminate this marking, it is causing issues with our shop process.
I found the issue!! It was in Database/Fittings/Pattern Options/Notches. The "Tool" field I assigned as Air Plasma which was causing the unknown round notches. Once I switched back to Default Cutting the markings went away. Hopefully this will be corrected with the next update.
