Marker Notches on CID: 4 (Radius Elbow)
On CID: 4 (Radius Elbow), if you have marker notches enabled and setup correctly, it will only notch the Heel / Throat. It will not apply a marker notch on the cheeks. (See attached pictures).
The marker notches  appear on square fittings (ex. CID:2 Transition). Can we get marker notches to work on ITMs with a radius please?
Thank you for your consideration,
Nick
1 Comment
aaron.tw
Status changed to: Gathering Support
