Currently the Insulation Spec is applied to the Service.
This doesn't allow different insulation settings to be used on different shapes (round/rectangular/oval).
I want to be able to apply a different Insulation Spec to each tab.
So for example I can have internal liner applied to rectangular duct, outside insulation on round, no insulation on some objects, etc.
This could also be used for different situations like exposed vs. concealed.
I could just exclude the appropriate tab when dealing with exposed/concealed areas.
nbaughman had a similar issue/idea, but he was suggesting changing the insulation spec itself to allow different inside/outside settings for the different shapes.
I would like to keep the insulation specs the same, I don't want one spec that has both internal and external, I just want to apply the specs with more control.
Link to his idea here:
