I'd like to have the ability to drive/change the Support Rod Specifications per instance of support in a similar way we can override the rod diameter. The rod dia changes depending on the material of the pipe being supported and we can only have 1 Support Rod Specification per Fabrication hanger. Instead of having multiple hangers in the library just because of the Support Rod Specifications. Id also like to be able to set this via the API.
