ESTmep Improved Annotation
Request for improved functionality with annotation in ESTmep on the following:-
  1. In CADmep / Revit we use a construction code to identify the specification & thickness of internal / external insulation on ductwork / pipework. The code is associated with the insulation specification applied to the duct. It would be beneficial to have a similar option to apply ‘ctext’ on our trace estimation drawings so we can identify at a glance that the correct thickness / specification of insulation has been captured for costing. (See Attachement 1)
  2. Improved options to specify where annotation is located on items as can be done in CADmep. Currently the default locations for annotation in ESTmep are not ideal. (See attachment 2)
  3. Option to scale linetypes or more linetype selections so lines for insulation / lagging are displayed dashed when printing trace drawings. (See attachment 3) Dashed line has already been selected in the example attached but results are a continuous line when printing to scale.
1 Comment
aaron.tw
Status changed to: Gathering Support
