Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Dynamic Hole Adjustment applied to the connector
As of now the dynamic hole adjustment is applied at the pattern level.
This should be applied at the connector level. This would allow the hole to be adjusted for inside taps.
4 Comments
Thank you for the input. THis was helpful!
 Click on the "Options" tap and go down to "Dynamic Hole Adjust" and set it to -1.5, if you are using 3/4" Inside Tap. This will adjust your opening size for Inside Taps.
andy.robins
Status changed to: ć‚Ŗćƒ¼ćƒˆćƒ‡ć‚¹ć‚ÆåÆ©ęŸ»č½éø
andy.robins
