Addition to "Change Specification" Dialog
In CADmep, when utilitzing the command "CHSPEC" you are given the options to "Auto Repair Straight Lengths" and "Don't Allow Template Fittings to be Stretched" (See attached)
As of right now, you have to open your drawing in CADmep, perform the CHSPEC then CREATECAM your job back out, or fix items manually while in CAM / EST.
Can we get this functionality added to CAMduct and ESTmep please? It would save time when having to change specs on items that have different standard joint lengths.
Nick
2 Comments
LanceTSM
This is an essential tool for use in CAMDUCT as it is there that the manufacturer needs the ability to change straight lengths of drawing from different clients to match the local manufacturing machinery.
We get .maj files for manufacture from various clients with different standard lengths, but we do not have the CADmep program so we are forced to do these changes manually, so having this tool function available in CAMDUCT would save a lot of time and effort before manufacture.
aaron.tw
Status changed to: Gathering Support
