-0 = bylayer
-0 = bylayer
Currently you can set the insulation color to "-0" and it will come in as the same color as the pipe or duct. I would like to be able to set the connectors to "-0" or by layer so they can have the same affect. See attached images
3 Comments
nbaughman
I must be confused, is that not what the 256 value is doing? All my flange out / flange in connectors have been using the same color as the duct per the service settings. Are you talking about when you change the layer color manually within AutoCAD?
Novybec-YD
Also, when exporting your MAJ file to Revit, the flanges will only show IF the connector color is set to 256 in your database.
aaron.tw
Status changed to: Gathering Support
