What does “E” stand for?
ysautodesklover
ysautodesklover
Hi all,
I found E in the item pallet.
What does it mean by that?
nathan.chapman
The "E" stands for Excluded.  If you were to convert Revit Duct/Pipe to fabrication parts any item with a "E" would not be used during the conversion.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
ysautodesklover
@nathan.chapman
Thank you for your reply.
So do you mean it can be used in CADmep or CAMduct but not in Revit?
craigjonnson
The Exclusion is defined in programs like Estmep, CAMduct or CADMep and is solely for the purpose of not using an item during designline. CADMep's equivalent to multi-route. The button can still be used by selecting that object individually. So yes, it is still available within Revit.
nathan.chapman
The exclusion will also work with Revit when doing conversion from native revit to fabrication parts
Nathan Chapman
