Weld Gaps
Weld Gaps
Weld Gaps
I went to folders and modified the shop weld to 0.0625. This is OK, but the problem is when I insert the weld. The weld will not match the size of the pipe. I have to type in the size every time.
MaddenDerrick
I would be very interested to hear what people have to say about this. I seem to even be struggling on where you setup the weld gap for auto insert? It works in the OOTB service, which is great but I would like to know where this is setup.
-DM
davidronson
This is done through connectivity, your pipe connectors should be Male, and the weld connectors should be Female. They also need to be in the connectivity group.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
davidronson
Sounds like you probably changed the wrong value. Your weld should have a Product List that contains all the relevant sizes. You will need to change the length of the weld in the Product List.
