Viewport Problem - Hide Object In Viewport Affecting Multiple Viewports
Hi All,
Hoping someone can help with this problem. I am working on a drawing with multiple viewports and am using the command "hideselectedinvp" to hide some objects. However when I use this command in one viewport it is actually hiding the items in multiple viewports rather than just the one I am actively working in. This causes a problem when I plot the drawing as I need the items to show up differently across the viewports. I do not know why they seem to be linked in some way - See attachment for info.
I have tried a number of different ways of recreating the viewports, creating from new, copying, regen, regenall. Nothing seems to work - everything looks fine as a 2D Wireframe but these viewports need to plot as Conceptual which is when I have the problem.
Any and all help or advice would be appreciated.
Stephen.
cadman_ics
Hi Stephen,
I was able to use that command without issue, so I would guess something is messed up in that file.
Maybe try WBLOCK to get your items into a new file.
My sample:
