Viewer in Viewer
Viewer in Viewer
When I refill in a project it pops a window called Viewer in viewer. I have tried to reinstall, repair, delete and install and it still shows up. It does not happen to others using the program is there a wasnippy to turn it off?
davidronson
Go to Main Database>Takeoff>CAD Settings>Collision Check>Design Line Collision Checks and disable this option. It is running a collision check for you.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
davidronson
