Victaulic Pipe Straight Lengths
cadgroup2
cadgroup2
New to Fabrication CADmep.
I imported the AWWA fittings from Victaulic website. I can import the fittings (elbows, ect) into my drawing. I see the "attacher" at one end of the fitting, but I can't attach straight pipe. Is there a Victaulic straight pipe somewhere?
-Jim
cadgroup2
From Victaulic:
"Regarding the CADMEP files, these are transport services. You can place them anywhere on your PC and then while setting up your service you can take Victaulic products and add them."
Copying the Vic parts to an existing System with pipe works. The straight pipe is shortened to the correct cut length when adding a Vic fitting. Being new to CADmep, I didn't realize this.
mroble
What I did, was copy another pipe, say "Beveled End", both the ITM and the jpg files. I renamed them from "BE" to "Grooved", I entered the renamed ITM, changed the connections from Beveled End to Grooved, added them to my Vice Service, and voila, you have grooved pipe.
I just downloaded the Vic stuff myself, and there's a lot of content, but the actual Service isn't set up, and needs cleaned up, but the hard work of the ITMs are there, so it's just a matter of cleaning it up.
Note: Make sure you grab a pipe that doesn't have a locked length applied, say "20 ft" or something. But if you do, no biggie, just unlock the length. So you can change it while inserting it.
cadgroup2
Thanks mroble for the info
mroble
@cadgroup2
 Anytime
