True Type Fonts in sectional views
clomedico
clomedico
when i try to use a true type font in a sectional view it shows all labels in all views.  Is the re a fix or workaround?
clomedico
Hello Christopher,
thanks for the drawing, I see what you mean and I can reproduce on my own.
I can't really suggest a workaround other than:
- edit the text Style temporarily and set the font to a non True Type one when loading a sectional view;
- hide the dim/text/numbers/... layers, this hides everything though.
Note: I can reproduce using the AutoCAD DVIEW command that allows to Clip the view and a normal text, so not related to CADmep tags and Sectional Views only (in the end those are based on Acad features).
I can just report to the developers for now.
Best regards,
Andrea Mazzoldi
Autodesk Support Team
