Trimble Field Points add on
I am trying to place Trimble Points on hangers and other objects using the "Place Points Over Blocks" command. The problem is that CADMEP objects are not perceived as "Blocks" by Trimble Field Points. Is there a way to twick my hangers in order to make them appear as blocks to TFP?
CADMEP hanger already can export points, Nothing needs adding.
I understand that. The "Trime" command will do the trick. I was wondering if there was a way of using Trimble Field Points plugin without "Trime" and have hangers and sleeves recognized as blocks by the plugin.
Thank you
Not that I know of.
If it's just block position you want you can use DATAEXTRACTION
That will allow you to export a .csv file of the coordinates
