Transitions or fittings coming out wrong on flat side.
cweaver7
cweaver7
After entering in transitions with flat on bottom or vice versus they are processed at the table as opposite of what was drawn.
Mike_Arcari
hi there
there may be 1 or more reasons for that happening.
1-If you are drawing them from the 3d take-off screen then your attacher arrow must be pointing left otherwise they come out upside down.
2-the other reason is that you have the patterns flipped on your plasma or laser cutter
this can be fixed if you go to databse settings, fittings, developments and make sure you tick or untick the box that says part labels on inside. this will flip the developments on the plasma. i have the outsides facing up so labels on outside but you may do it differently.
i cant think of another reason why they would be back to front or upside down so i hope that helps
cweaver7
Yes, sir that was the case, the box was checked for the labels on inside. Appreciate the help.
