11:43 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How to get a list of CID's?
Think you might find this link helpful:
http://help.autodesk.com/view/FABRICATION/2017/ENU/?guid=GUID-19474666-9319-4539-8FEB-AC625B9D37E2
I attached the 2017 Pattern Catalog put together by Applied Software. I assume the AS catalog is complete, but in case it isn't I also attached a text file we created with the .Net API. We recently used the API to create every pattern ITM between 1 & 5000 for testing of VLA properties. So, that text file represents the ones that didn't error.
When CHANGES are made to the CID file do you CHANGE the CID number and/or list a revision number?
Sometime we have CID files that do bot behave as we expect. Reloading the same number CID sometimes fixes the problem.
